94 jgc power window problems
dspreacher
02-28-2005, 01:10 PM
Power windodws will not work. fuse is good. Main switch panel seems to test good. Anyone have any suggestions? Also am in need of info to fuse block, do not have owners manual to tell me which fuses go to what. Lastly, the are relays behind the glove box insert. Anyone know which ones control what in the vehicle? Thank you for any and all help.
smokeandlights
03-01-2005, 03:06 PM
The fuse box lid lists which fuses and relays do what for that position. The glovebox relay center, I don't know for sure, but look at my thread from a few days ago. Someone posted what they thought was in there.
I have a pic of the fusebox lid label. if you need it, just email me.
kwjs
03-02-2005, 10:22 AM
If it is all of the power windows not working from using any of the switches check the wires that run thru the rubber boot between the drivers side door and the body. There you will more than likely find a broken ground wire..and maybe a few others..that is causing your problem. All of the windows go thru the drivers switches before going to the others. I had this happen to mine and as soon as I soldered the wires back together every window worked great! Good luck! Sorry I don't have the other info at this time..
