Brights & fog lights
Google
Web AF
LT1MAN
02-28-2005, 11:20 AM
can someone tell me how to rig it up in a 94 camaro so that you can have the brights and the fog lights at the same time?
i know it is possible because in the generic gm photo for that car all the lights are on.
thanks :smokin:
FormulaLT1
02-28-2005, 11:53 AM
Tools Needed:
Flat Head Screwdriver
Philips Head Screwdriver
Wire Cutters <HR>
Parts Needed:
Appx. 18" Of Wire
Electrical Tape
<HR>
Purpose:
Wire fog lights to stay on with hi-beams. <HR>
How - To:
Step 1
Disconnect negative battery terminal. Open fuse box under the hood on the drivers side (near the air box). Find the fog light relay (Block H).
Step 2
Remove the fuse box from the frame. You will have to push in the 6 plastic retainer clips that hold down the box. Pry up the box.
Step 3
Look on the bottom of the box under the fog light relay fuse. You should see 4 wires (orange, yellow, purple, light green).
Step 4
Cut the light green wire. Take the 18" wire you have & splice it to the wire coming OUT of the fuse box. Take this wire & ground it to one of the bolts holding the fender on the car. Make sure the wire doesn't interfere with anything else under the hood.
Step 5
Tape the dead end of the light green wire coming out of the harness.
Step 6
Reassemble (the box snaps into place) & test lights.
Step 7
Note : The light on the fog light switch on the dash still goes out when the hi-beams are on.
CamarosRsweet94
03-01-2005, 01:45 AM
Wow, that's so in depth it's almost scary... I am however impressed with the quality and simplicity of the instructions. You do good work John.
LT1MAN
03-01-2005, 02:05 PM
thanks formula, do you have this done to your car?
FormulaLT1
03-01-2005, 02:21 PM
Nope, Formula's don't have fog lights.
LT1MAN
03-02-2005, 11:17 AM
what is different about a formula than a regular lt1 transam, or i guess just tell me what they all are hyerarctically.
FormulaLT1
03-02-2005, 12:03 PM
Formula's have the powertrain of the Trans AM but looks like the Firebird. The Formula's is the lightest 4th Gen F-Body's but come standard with the least amount of standard equipment such as Foglights which could not be had on the Formula.
John
LT1MAN
03-02-2005, 01:11 PM
ok what about this
trans am=z28?
ws-6=SS?
firehawk=?
FormulaLT1
03-02-2005, 01:17 PM
ok what about this
trans am=z28?
ws-6=SS?
firehawk=?
Trans am=Z28
WS.6/SS/Firehawk, pretty much all equal (All SLP modified, via either parts or at there factory in NJ).
bag91
04-28-2005, 10:15 PM
Trans am=Z28
Isn't the Trans Am much heavier than the Z28?
http://files.automotiveforums.com/gallery/watermark.php?file=/503/330777Copy_of_23_017.jpg
FormulaLT1
04-28-2005, 10:26 PM
If you consider around a hundred pounds depending on the options of the models your comparing "much heavier" than yes but in terms of performance times they are dead even for most years that they had the same powertrain but going by weight the Z28 would have at most a 1 tenth of a second advantage although it doesn't appear to show that much of a difference
88irocZ
07-18-2005, 12:35 AM
dang talk about bringing up an old topic... but will those instructions work on a third gen? im sure they will i was just making sure.
Google
Web AF
