05 lift using torsion keysabadassbowtie 02-27-2005, 09:54 PM Ok I was reading old posts and all I can find is that the torsion bar keys from the fords are what I want to use I was woundering what year keys to use on a 05 and how much of a lift will they give me. And does anbody have the part number that i need to order. Then I am going to put the add a leafs in the rear. Thanks J-Ri 02-27-2005, 10:19 PM That's not a good way to get a lift. Get the taller springs and longer shocks. To answer your question, you could get a couple inches out of the torsion bars. jeverett 02-28-2005, 07:49 AM How can he get taller springs with the torsion bar suspension? The bar is the spring right? abadassbowtie 02-28-2005, 09:44 AM I do not have coil springs so I Was just going to do keys in it but I am trying to figure out which keys I can order to put in I found kits on ebay. But it seems like they are asking to much for the keys and the add a leaf's. jeverett 02-28-2005, 01:29 PM Check this thread out... http://www.automotiveforums.com/vbulletin/showthread.php?p=2739080#post2739080 skipr 02-28-2005, 08:29 PM How can he get taller springs with the torsion bar suspension? The bar is the spring right? You are correct, no coil springs J-Ri 02-28-2005, 09:54 PM How can he get taller springs with the torsion bar suspension? The bar is the spring right? I mean for the rear leaves, rather than getting blocks. For the front, there is a lift spindle that you can get. It uses the stock torsion bars. J-Ri 02-28-2005, 09:56 PM I jsut re-read the first post, it was either edited (removing blocks as an option), or I am going crazy. Possibly both. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
