engine mounts
ekmarsal
02-27-2005, 01:01 PM
Hi. How do you know 100% that the engine mounts need replacment. The engine has a rough idle in drive and when I stop at lights. RPM is good, just changed the air filter and cleaned MAF sensor ( I thought it would be this ) but the problem is still there. I'm trying to figure out how to check if the mounts are bad. Thanks.
beyondloadedSE
02-27-2005, 01:20 PM
Take a look at the roll restrictors under the car. You can usually just look at them and see if the rubber within the mount is intact.
