2003 F150 Misfiring
Google
Web AF
davejohn_tx
02-24-2005, 10:10 PM
My F150 has only 40,000 miles and it is misfiring. Anyone know what would be the problem. Installed new sparkplugs and same problem after a short while and the service engine light came back on.
ModMech
02-25-2005, 03:38 AM
The Coil On Plug (COP) modules are a weak spot. It will FAIL emissions if it is misfiring, and if it actually does fail, Ford whould cover the repairs.
jcl27
02-26-2005, 07:56 AM
How would ford cover the repair with 40000 miles? Warranty is good
to 36k unless he bought an extended warranty
steve in alaska
02-28-2005, 02:31 AM
not to state the obvious, but if the service engine light came on, do you have access to a code reader? If not, it may be cheaper (in the long run, rather than troubleshoot yourself without one, swapping parts etc.) to take it in to a shop and get the problem code read/analyzed..unfortunately "newer" vehicles are run by computers, but then again, problems can also be diagnosed easier. I for one (being my own mechanic) invested in a good scanner, and have never regretted it. The cost was recouped rapidly..would have cost me the same with about 5 trips to the shop, just for a diagnosis. Good luck.
Steve
CauldronBorn
03-03-2005, 08:36 AM
Most autoparts store will scan the error cades for free now a days. It's a ploy to get you to buy your parts there.
rairigh808
03-14-2005, 03:00 PM
mine did the same . have an auto part s find out which cylinder is misfiring. it probably needs a new coil on that cylinder $50 at auto zone that is whhat i had to do
Google
Web AF
