113k miles now what???
Google
Web AF
Leatherwulf
02-24-2005, 12:50 AM
Howdy all-
My 96 tacoma has passed 100k, what should I look to replace soon?
So far it has only had the starter die. I think the plugs/wires are from the factory, but i'm gonna replace them asap.
thanks
Brian R.
02-24-2005, 01:07 AM
If the truck runs well, don't bother with the wires. Replace the plugs, PCV valve, accessory belts, lube everything including your transmission, check your brakes - flush brake system, replace air filter, replace antifreeze - flush cooling system, replace power steering fluid, check torque on propeller shaft bolts, check boots on half-shafts, shocks, ball joints. Clean throttle body and injectors.
Leatherwulf
02-24-2005, 12:22 PM
It's almost paid for so now i'll use my "payments" to doll her up a bit.
Google
Web AF
