opinion, I need New RIMS !Netopr 02-22-2005, 08:01 PM Hi there, I need an opinion of this rims: http://www.wheelguys.com/shop/details.asp?prodid=MSR116Special&cat=27&path=3,27 I own a lowered black cavalier (1999, 2.2L), with white corner and bumper lights. Classicrocjunkie 02-22-2005, 08:12 PM for some reason i am partial to that style of rim... hmmmm.. little iffy about the brand though. Never heard of them. Netopr 02-22-2005, 08:16 PM well yeah they are cheap rims but I am a student and its hard to get some paper :S.... They are better than 15" hub caps though with like 205 15 65 tires :( I like the first ones here: http://www.wheelmax.com/Specials/specials.html Classicrocjunkie 02-22-2005, 08:31 PM that tire size is wrong for your car. It will throw your speedo off almost 5mph. The correct tire size is 225/45/-17 for 17's wheel and 225/40-18 for 18's. Also they are super low profile and will look ghey. Netopr 02-22-2005, 09:19 PM oh i c I am realy a nub, can a 215 17" 40 and 205 17" 40 tires fir the same rim ?, whats the difference? I am running 205 right now with my 15" stock rims Classicrocjunkie 02-22-2005, 09:28 PM tisk tisk... your 15" stock OEM wheel should be 195/65/15. Z24 are 205/55-16. You can run really any tire that end with a 17 on a 17" rim. If its not the exact number you need, your speedo will be off and can cause a problem with the cops. If your gettin 17".... 225/45/-17 is the proper size you need. Netopr 02-22-2005, 09:37 PM oh I understand Netopr 02-22-2005, 09:39 PM This website says: For 45-series tires, you will want a tire that is 205 mm wide so Ill use 45-205mm or 40-225, Is there really a big difference in heith ? check : http://www.dsm.org/tools/tiresize.htm godenm 02-22-2005, 09:44 PM Yeah,i Had 205-40 17's And My Speedo Was Off Like 4 Mph Too Low,but Now Ive Got 225-40 18's, So I Think Ill Be Ok Now.what Color Cav Are You Putting These Rims On? Netopr 02-22-2005, 09:49 PM Yeah,i Had 205-40 17's And My Speedo Was Off Like 4 Mph Too Low,but Now Ive Got 225-40 18's, So I Think Ill Be Ok Now.what Color Cav Are You Putting These Rims On? black but for 45-series tires, a tire of 205 mm wide will be safe ? will that put my speedo off by alot ? I mean 2mph will not be a problem ^_^ 01Cavy 02-22-2005, 10:26 PM well yeah they are cheap rims but I am a student and its hard to get some paper :S.... They are better than 15" hub caps though with like 205 15 65 tires :( I like the first ones here: http://www.wheelmax.com/Specials/specials.html I'm getting the BK-7 18" rims in that same brand. I'm getting the gunmetal rims. I have a white 2.2 4door cavy...like crj's only newer lol. I have yet to lower it though...won't be much since I will be putting 18s on it. http://www.wheelmax.com/Wheels/exel/exel.htm Just scroll down a little bit. Netopr 02-22-2005, 10:45 PM I lowered mine with coilovers and the front came out nice but the back looks almost the same as stock. If I only knew were to buy lower strut upper mounts for the back :/ This is my coilovers: www.vaos.net They must be cheap shit lol, I bought them on a website without any knowledge. BTW they dont bounce or make any noice at all. 01Cavy 02-22-2005, 11:15 PM hell for $300 I'd be pissed if it didn't come out right. By the way...CRJ you finally get a body kit? Looks good if that is indeed yours. Classicrocjunkie 02-22-2005, 11:57 PM I'm not unvailing what i have done to you guys till this fall when she goes to sleep for winter. Thats just a little taste of whats in store. If my plans work out, all you will see if a body with no engine for a little while and will be recieving some well.... have to wait and see! 01Cavy 02-23-2005, 11:49 PM Ah. Makes me wish I had money...I'd drop my 2.2 out and put in a 3.8 and twin turbo it. Then work on the outside noshun 02-28-2005, 03:12 AM the 195/205/215 is the width of the tire in mm the 45/50/55 is the sidewall height (each side of the rim) as a percentage of the width e.g 205/50 the sidewall each side of the tire would be 102.5mm and 205mm in total. I never understood mixing inches and metric on those though and that's the worldwide system! You can work out the rolling circum of each wheel and tire combination and then the difference it will make on the speedo. It wont be as high as 5mp though. But if you plan to mkae a sleeper aren't 17's a little showy? I'm not going over 16" for performance reasons. Probably Enkei or OZ. BTW MSR aren't actually that bad a company for wheels and those have been around for about 4 years now! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
