93 oil leak
Google
Web AF
hottmamita
02-21-2005, 08:21 AM
i am far from car-friendly so ill try to explain this as best as i can. My 93 camry has an oil leak. It is coming from the front right side of the engine if you stand in front of the hood. I was told its a sensor but i dont know anything about it. Its not a bad leak, its a drop every few minutes. nothing big. My engine looks like someone took some sealant of some kind and took it along the the engine i think where it is sealed. does anyone know what im talking about? im sorry that i cant explain it any better. if you stand in front of the hood its on the front of the engine block to the right. how do i fix that or am i gonna have to shell out some dough to have someone fix it?
Thanks
llllllllll
02-21-2005, 10:04 AM
Thanks
hot mama,
if you can show us pictures, the pictures will do the explaining for you.
hottmamita
02-21-2005, 11:22 AM
ok let me see what i can do about taking some pics and ill post them as soon as i have them
rum runner
02-21-2005, 04:53 PM
The right side of the engine could be the rear oil seal OR the valve cover. The distributor o-ring usually runs down the middle of engine.
I would tighten the valve cover and use some Bar's stop leak for engine oil. Rear oil seal replacement is a big job.
ProMan
02-22-2005, 11:43 AM
Are you talking about the oil pressure sensor? That one has a wire connected to it and it's like round. If that's the one you are talking about, take it off and apply some sealant and screw it back on. that should seal it.
hottmamita
02-22-2005, 12:59 PM
I think so, it looks like it clips on and has some wires in it. it is round and it connects to the right side of the engine. I took some pictures so if anyone wants to see exactly what i mean please let me know but i think the oil pressure sensor sounds right.
Im gonna give that a try and hopefully thats all ill need to do.
Thanks a lot ProMan!
ProMan
02-25-2005, 05:34 PM
You are welcome.
Sunliner
03-01-2005, 09:52 PM
I've got a '97 4-banger with a similar problem.
I checked the valve cover but I think it's from what I *think* is the oil pressure sensor. The leak definitely is from the area around the timing belt housing, & since I've ruled out the valve cover, I don't think there's anything else in that area to leak from.
Does the sensor plug in near the timing belt housing on the '97? Or is that something else I'm looking at?
Google
Web AF
