a "weird" smell??
mike1224
02-18-2005, 09:46 AM
While driving the other day my friend told me that he smelled a "weird" smell coming from the vents. i have never noticed anything before.. is my friend trying to worry me or might he be on to something??
BlazerLT
02-18-2005, 11:09 AM
need to know what this smell was.
blazee
02-18-2005, 03:02 PM
Did you fart right before he smelled it? http://forums.consumptionjunction.com/images/smilies/fart.gif
mike1224
02-18-2005, 03:05 PM
THE SMELL WAS COMING FROM THE VENTS..
mike1224
02-18-2005, 03:22 PM
The only was he's able to explain it to me is that "it gave him a bad headache." Well, i just woke up and talked to him, He said It could be coolant. Which I think is Bull-twinkie, b/cz i don't have a leak. I just did a coolant flush a month ago at 58,000 (i have also done one at 52,000). and i hopefully would have noticed some orange fluid dripping on the ground since then, and my back-up resivor still has coolant up to the cold line right now.
dugie6551
02-18-2005, 03:50 PM
....He said It could be coolant. Which I think is Bull-twinkie, b/cz i don't have a leak.
It could be a coolent leak from the heater core. The heater core is up under the dash and it provides heat to the inside of the cab. When there is a leak, it does smell. Take the rad caap off (when it is cold!!) and smell the rad fluid. If it matches the smell that is coming from the vents then BINGO !!! you need to replace the heater core. Also, if it is the heater core there might be rad fluid on the passenger side floor area.
whiteS10
02-18-2005, 03:56 PM
It sounds like you could have a leak in your exhuast manifold causing a smelling coming into your cab.
blazee
02-18-2005, 04:15 PM
Before doing any repair work, you should try to smell it yourself. Start the truck, turn on the vents, and close it up. Stand outside a few minutes, get some fresh air, then jump in and sniff the vent. (don't let the neighbors see you or they will probably think you are crazy)
mike1224
02-18-2005, 05:42 PM
it doesn't smell like coolant. i closed the moonroof and noticed a faint smell. But since i almost always drive with the moonroof open (even a tiny bit in winter) to hear sirens. I think it smelled like something that I was trying to hide one day.... might explain a few things :)
BlazerLT
02-18-2005, 07:58 PM
Comon, the smell has to smell like something.
Mildew, oil, coolant, smoke...WHAT?!
mike1224
02-19-2005, 12:26 AM
smells like maryjane.
BlazerLT
02-19-2005, 09:36 AM
Huh?
Gimmie a break, the smell coming from your vents smells like grass?
BWHAHAHAHA!
mike1224
02-19-2005, 03:56 PM
it was an ounce, and well, the heat... that's just a good combonation until I get pulled over again.... but i really should get that taken care of. i have better things to do anymore than get high; and i realized that it's just a waste of time/money. i need both
BlazerLT
02-19-2005, 03:59 PM
What?
Can you start making sense please.
dmbrisket 51
02-19-2005, 04:14 PM
he says he is/was a baker, and he had to hide some stuff one night, and he has never retreived it from where he ditched it... and now we have a smell
BlazerLT
02-19-2005, 04:58 PM
lol, well, he is going to have to live with it until the smell wears out.
blazee
02-19-2005, 05:05 PM
He could always have a party and set the truck on fire.
BlazerLT
02-19-2005, 05:36 PM
:lol:
kenyonja2007
02-19-2005, 06:15 PM
So lets see, you posted a question about what people think the smell might be and if you should be worried about it or not, and you outright know what the smell was all along? And on top of that it was illegal drugs. If you have a technical question about a car, post on automotive forums, don't ask how to get a drug smell out of a car.
blazee
02-20-2005, 07:32 AM
In the pothead's defence...he didn't know what the smell was when he started the thread. He thought there actually was a problem.
mike1224
02-20-2005, 10:06 AM
it was my roommate who thought there was a problem at first, i guess i got used to the smell. But yes, when theres an uncommon smell coming from your vehicle theres always some worry. well i gotta learn to pick up what I put down (or hide) on the plus side, it gave me time to clean my truck.
mike1224
02-20-2005, 10:10 AM
1. I had no idea what the smell was he was talking about until ONE day LATER, after the original post.
2. The smell was different, not like a "burning" smell.
3. I NEVER asked how to remove the odor from my vehicle.
