no speedometer/odometer/abs light onscott_xrx 02-17-2005, 11:32 PM speedometer went out but, the anti-lock brake light came on. Has anyone else had this happen? GMCMudBogger 02-18-2005, 09:45 AM Speed sensor works with the ABS thats why the light came on, The ABS will not work till you get that speedometer fixed, Not that its a bad thing I hated my ABS anyway, When I put my bigger tires on & lift it screwed up the ABS too. jnearhood 08-23-2005, 07:44 PM Did you find your problem, I have the same thing happening. broughy84 08-24-2005, 12:52 PM this is probably a Vehicle Speed Sensor problem. uofkddecker 11-01-2005, 01:06 PM speedometer went out but, the anti-lock brake light came on. Has anyone else had this happen? did you ever find your problem i'm having the same problem can you help me? jnearhood 11-01-2005, 05:29 PM this is probably a Vehicle Speed Sensor problem. yes it was vehicle speed sensor. I replaced it and it solved the problem. uofkddecker 11-01-2005, 05:43 PM yes it was vehicle speed sensor. I replaced it and it solved the problem. I replaced the speed sensor and ecm didn't work thanks anyway. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
