Grand AM '92 V6 3300 "Check Oil" light
Google
Web AF
Herbstleyd
02-17-2005, 07:12 PM
Hi
a couple of week ago my "check oil" light come on, so i checked the oil level, it was missing a half-pint, i add it and the light still appear every times i start the engine and stay on for almost 2minutes
The car is a Grand AM '92 V6 3.3l 190 000km(118 000 miles).
anyone got an idea why this light is comming on ?
thanks
swalt
02-17-2005, 08:47 PM
If your pressure is ok, don't worry about it. Mine has done this since around 80,000km's and I have 170,000km's on it now. These model years are quirky for the oil light. If you check your manual, you will even see that it states the oil light can flicker from time to time while driving. They deem it normal, although it has been determined it is a bad solder point in the instrument cluster. As far as the problem you mention, I find mine stays on for about 30 seconds, is worse when cold, and always goes off right away after a fresh oil change, which would leave me to believe it has something to do with an oil sensor. It also shuts off quicker if I cycle the key first and then start the car.
Knifeblade_03
02-18-2005, 10:05 PM
Yeah, I agree, as long as oil level and oil pressure is to speed, it the sensor
Herbstleyd
02-19-2005, 08:32 PM
what is a good pressure for oil ?
what it mean if the pressure is high / low ?
thanks
Google
Web AF
