Slight Vibration felt/heard Right Frnt Wheel on Left Turn
JoshBarber
02-17-2005, 04:21 PM
Since I bought it, theres a slight vibration heard from the front left tire when I'm putting pressure to the left side with the steering wheel at high speed. I don't hear it on normal around town driving, mostly on the highways as the highway curves to the left. You can hear a real quiet vibration, and I believe I feel it through the steering wheel itself (very faintly)
Any ideas?
BlazerLT
02-17-2005, 04:41 PM
yip, right front bearing needs to be replaced.
When you turn left, it puts pressure on the right bearing.
JoshBarber
02-17-2005, 04:48 PM
Can you really be sure of that from just the info I gave you?
How hard is it to do myself?
Have you done it?
Cost of Parts?
Special tools?
Cost to have it done proffessionally?
BlazerLT
02-17-2005, 04:53 PM
Have you done a search yet?
Please do a search for information.
JoshBarber
02-17-2005, 04:59 PM
I ALWAYS do a search first. This isnt the first auto forum I've used. I know it's annoying to get the same questions over and over. Lot's of things cause noises, and vibrations. My point was, is it possible it's something else before I go spend the $150 on parts, and time replacing it?
i.e.- I don't want to replace the:
Lower Ball Joints
Passenger Upper Ball Joint
Sway Bar End Links
Sway Bar Bushings
Front and Rear Shocks
to find out it's a hood squeek with a $2 fix. get me?
BlazerLT
02-17-2005, 05:06 PM
Yes, I was telling you to do a search on the wheel bearing replacement procedure.
It has been covered before.
JoshBarber
02-17-2005, 05:13 PM
Was there any other things I should look at as well?
I checked that out. Thank you. Good photos etc. Just never done one before, so I'm clueless. AutoZone quoted me $150 for parts. Doesnt look horrible, but sometimes easy looking stuff ends up being the biggest headaches.
BlazerLT
02-17-2005, 10:23 PM
I would recommend buying a haynes or chilton's manual to help you through it.
It will have the guide on how to remove it.
JoshBarber
02-18-2005, 07:15 AM
I've got one, thanks
BlazerLT
02-18-2005, 07:39 AM
It doesn't have the procedure in it?
blazee
02-18-2005, 10:24 AM
You will need
18mm
36mm deep well socket
torque wrench capable of 103ft/lbs
