2000 Blazer headlight replacementaddnative 02-16-2005, 06:15 PM Can someone help me figure how to change the the front headlights. ricksza 02-16-2005, 06:25 PM Directly behind the headlamp, there are two retainers that slide down and lock the headlamps into place. Remove the headlamp assembly retainers by pulling up and outward. Disconnect the lamp electrical connectors. Remove the headlamp assembly from the vehicle. Push and rotate the bulb 1/4 turn counter-clockwise in order to remove the bulbs from the headlamp assembly. BlazerLT 02-16-2005, 08:20 PM also don't touch the bulbs with your fingers. It will cause them to fail prematurely. addnative 02-17-2005, 08:27 AM I looked everywhere behind the light and I don't see any retainers. I tried pulling the lights up and out but they won't budge an inch. swalt 02-17-2005, 10:48 AM They are two plastic tabs. The are shaped like an "L" (but upside down) and about 6 inches long. You can't miss them as they are right behind the headlight between your air breather and the back of the headlight on the right and between the battery and back of headlight on the left (when looking into the engine compartment from the front). Just pull both of the "L's" up on each side.. addnative 02-18-2005, 01:40 PM I can't see right behind the light, this is what I see. IMG]http://img.photobucket.com/albums/v446/soconfg/car/Picture.jpg[/IMG] swalt 02-18-2005, 04:37 PM Ok, I froze my butt off to go get you this picture. -14c in Toronto today. :smile: See the things where the red circles are? Pull them upwards and off and then you can manouever the headlight out. http://files.automotiveforums.com/gallery/watermark.php?file=/500/116754headlight.JPG rlith 02-18-2005, 04:55 PM Ok, I froze my butt off to go get you this picture. -14c in Toronto today. :smile: See the things where the red circles are? Pull them upwards and off and then you can manouever the headlight out. http://files.automotiveforums.com/gallery/watermark.php?file=/500/116754headlight.JPG Bravo!!!! flipcrip 04-22-2007, 03:32 AM is this the same procedure for a 96 jimmy slt....thanks vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
