Fuse Question!!notkidding 02-16-2005, 04:21 PM If you pull the fuse that goes to the "check engine light" and then drive it, can that cause any probelms? Someone told me that this can make the car go into "limp mode" and run rich causing problems in things such as the CAT. Is this true? boschmann 02-17-2005, 09:26 PM I don't know that you can pull any fuse that controls the check engine light on a '99 & still have the engine run. notkidding 02-18-2005, 03:58 PM Yeah... Well I found out that it does run... Someone had pulled it before I bought the car. Most likely the most disho0nest people I have ever met. The Dealership!!! Could this have caused any kind of damage? boschmann 02-18-2005, 06:01 PM Driving with the light on can damage certain things, primarily the catalytic converter. notkidding 02-18-2005, 06:10 PM Hince the reason my car is in the shop waiting for one right now... Those damn things are expensive!! $995 from the dealer. $595 refurbished. Damn CA smog wouldn't allow me to buy a aftermarket one. They don't make them for OBD-II systems. By pulling that fuse would that alone cause anything to happen? The MAF caused the cat to go bad, but would that fuse itself cause anything to happen? veedubmechanic 02-21-2005, 12:42 AM There arent any fuses that control the check engine light or ecm vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
