5 speed thumps when i let off the clutch sometimestacoma man. 02-16-2005, 09:17 AM is it normal, it does it when i let out on the clutch. usually does it in 5th gear. bearcat329 02-16-2005, 04:02 PM aye, mine does as well, have to shift iin perfect synch with throttle and clutch release. mines a 96 4x4 ext taco, 170k on the drivetrain. any ideas folks? tia Rick, Ore tacoma man. 02-16-2005, 07:47 PM i guess ill just need to grease everything and have my tranny serviced Brian R. 02-18-2005, 08:45 AM Try greasing the fittings on the propellor shafts. You might have dry splines. tacoma man. 02-18-2005, 04:15 PM i will, seems to be ok when its warm out. so i will grease everything up. Brian R. 02-18-2005, 09:02 PM Some Tacomas have a problem with rear-end wind-up. Search this forum for discussion. erichz 02-19-2005, 02:34 AM i've found that my 2000 4cly does it also in 5th gear especially. Yeah, you have to have a perfect shift, real slow and steady, but who does that? Maybe i'll just grease the splines and everything, but i'm not gonna worry about it. I just put a new tranny in a jeep wrangler with 117000 on it, the old one was completelywrecked, gears were gone. I've never heard of anyone having catastrophic tranny failures in a taco, because it's a superior machine. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
