Need Help With Firing Order!91Cav.Z24(3.1)Bmh_icp 02-15-2005, 11:50 PM Well the other day I found out Coil Pack was bad so I changed it. Car still only ran on 4 Cyclinders. So I took and wrote the numbers down from each coil pack and taped them to the wires. Then proceeded to take off ign. module. Got it tested it was bad. So bought new one put everything back on in the order it was when I took it off. Now it won't start. So I was wondering where to get wiring diagram of SparkPlugs and coil packs so that I can tripple check to make sure I didn't mess them up when taking them off. Can anyone please please help me out? Thanx Jeff noshun 02-16-2005, 09:24 PM Well the other day I found out Coil Pack was bad so I changed it. Car still only ran on 4 Cyclinders. So I took and wrote the numbers down from each coil pack and taped them to the wires. Then proceeded to take off ign. module. Got it tested it was bad. So bought new one put everything back on in the order it was when I took it off. Now it won't start. So I was wondering where to get wiring diagram of SparkPlugs and coil packs so that I can tripple check to make sure I didn't mess them up when taking them off. Can anyone please please help me out? Thanx Jeff Believe it or not 1-2-3-4-5-6! That is 100%. A haynes manual will tell you though! Whats the problem causing you to ask? Just in case I can offer further help! IFIXCARZ4U 02-19-2005, 12:28 AM If the coil packs are mounted under the front exhaust manifold. The plug wires hook up as 1-4-6-3-5-2 as you stand in front of the car looking at the engine. If the coil packs are mounted on top rear of the intake manifold, The plug wires hook up as 2-5-3-6-4-1 as you stand in front of the car looking at the engine. noshun 02-19-2005, 12:37 AM I tell you I must have not read the orig psot properly! Maybe just the title! I would have done a diagram for lead positioning. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
