camshafts...
Google
Web AF
screwakangar00
02-15-2005, 08:13 PM
I was thinking about purchasing a camshaft off of pfyc.com, and i was wondering if anyone has tried them and was curious what they sound like, i kno they sound good on V-8's but i was unsure what they would sound like on a 3.8 V-6?
Also, what would be a good choice for an exaust system that would sound good and powerful??
BIG-L
02-15-2005, 08:27 PM
There is also 2 other site's that sell cam's for GT's and GTP's
http://www.zzperformance.com/products.php?id=104&PHPSESSID=6725d97c208aafc65947e4bef1bc5386
www.intense-racing.com
BIG-L
02-15-2005, 08:31 PM
Also not sure how many miles you have ,but to keep from getting valve float,you might think about new LS1 valve springs and some new retainer's.
screwakangar00
02-15-2005, 08:47 PM
68,000
BIG-L
02-15-2005, 08:52 PM
68,000
Yep,Id add those to your list.Also keep in mind that to big of a cam can also cause the computor to think you are getting missfire's (lope of the cam).
Do you have any other mod's done to your car??
screwakangar00
I forgot to add in my last message, that big-L you seem to know more about grand prixs than pontiac does, ive only been a part of these forums for a few days and you are by far the most helpful person on here.
BIG-L
02-15-2005, 08:54 PM
Thanks
screwakangar00
02-15-2005, 08:56 PM
Big-L
All i have is a cold air intake. but i just finished paying off my car so i plan on doing alot more now that i have the money, so if you have any other mods you recommend im all ears...
BIG-L
02-15-2005, 09:02 PM
Before you add a cam,it wouldnt hurt to look into getting a PCM,U-bend delete.
I take it you have a GT ??
BIG-L
02-15-2005, 09:10 PM
Opps.... also some header's or ported exhaust manifolds with a 3in down pipe and high flow cat and a High Velocity Throttle Body
screwakangar00
02-15-2005, 09:15 PM
I do have a GT, and regarding PCM i am a lil skeptical cause i hear they cause more damage than good. As far as the U-bend delete, i read a forum about it yesterday and i was considering doing it...
Thanks agian
BIG-L
02-15-2005, 09:18 PM
What have you heard??Ive only heard nothing but good things about them and have never had a problem with mine...Ive got one of the first ones out and it's been in the car since 2001 from the grandprixstore and never a problem.
screwakangar00
02-15-2005, 09:26 PM
Ive heard they can burn out your engine because the make it go to higher RPM then its supposed too, but ive never heard it from a GP owner, and like i said earlier you know enourmous amount about GP's so ill agree with you.
Also about the u-bend delete, were would i pick up a straight pipe like that? just any autozone type store?
BIG-L
02-15-2005, 09:31 PM
Take and print out the picture from that post that I had responded to.Take it with you to a custom exhaust shop and they should be able to make you one or you can buy one from the PFCY in the exhaust section,then have an exhaust shop install it for you.Make sure,before they do any welding to remove the O2,Ive heard of them getting burned up.
http://www.pfyc.com/store/merchant.mv?Screen=PROD&Store_Code=PFYC&Product_Code=WB5001&Product_Count=3&Category_Code=GPEXH
screwakangar00
02-15-2005, 09:42 PM
I was reading about the PCM and it says.. "More radical modifications (such as camshaft changes and head porting, etc.) should consult with Digital Horsepower Inc. technical assistance first."
is this just a disclaimer type thing? or should i really not put cams in, cause i would prefer cams over the PCM.
BIG-L
02-16-2005, 04:33 PM
is this just a disclaimer type thing? or should i really not put cam in, cause i would prefer cam over the PCM.
The are saying that those mods can require a custom program.
If your wanting a cam,a reprogramed PCM is a must have or your not going to fully benefit from the cam.
Like I said above in this post,some cam's will cause an SES light to come on,because of the lope of the cam.The only way to not have that, is for a custom programed PCM.
This is what a DHP V1.0 does.
FEATURES:
- Speed limiter removed
- 3-1 and 4-2 skip shifts (Active in performance shift mode only*)
- Transmission line pressure increased (Active in performance shift mode only*)
- Shift points moved (5800-6000rpms) (Active in performance shift mode only*)
- Fan turn on points altered:
- 186 degree turn on
- 2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
- MAF calibration adjusted for proper operation and year
- Digital Horsepower Inc. fuel/spark adjustments:
- En-richens fuel delivery for critical problem areas
- Provides a consistent power gain across the entire power band
- Reduces spark retard (knock retard)
- Removes “40MPH WOT lag”
- Dynamometer testing has shown up to 20 HP gain
A PCM is about one of the first thing's to do on the 97/03 GT/GTP
I sure wouldnt ever go back to stock PCM unless I sold my car!
~Larry~
Google
Web AF
