Front Wheel Lockup
Google
Web AF
squashman
02-14-2005, 10:06 AM
I have a 2001 LS, 53000 Kilometers and equipped with ABS, . When applying the brakes with some force on dry roads, the front left wheel locks up. Is it a caliper problem or an ABS problem? Anyone have similar problem with their car?
Thanks
02impala
02-15-2005, 10:29 PM
Can you explain the lockup a little more...I have a problem where my steering locks up and almost feels like manual steering and cannot turn the wheel. I have a 2002 LS
squashman
02-16-2005, 01:42 PM
On applying the brakes, the front left wheel stops turning and leaves a rubber skid mark on pavement. The ABS does not stop wheel from locking up. Car also pulls to left when applying the brakes. It has nothing to do with steering.
squashman
02-18-2005, 03:09 PM
Had the car at the mechanics today and I was told caliper is OK. They suspect the ABS Control Module might be at fault. Anyone else have this part fail and what were the symptoms?
Thanks
contidog
04-27-2005, 06:07 PM
Thanks
I have a 2003 Chevy Impala LS and my brakes are locking up.....was told it was contamination in the fluid and would have to replace the entire brake system to the tune of $3000. I am fighting and would like to see what I can do. Need to contact BBB and go to arbitration...has anyone done this before?
bobss396
07-21-2005, 08:58 AM
You may have a bad brake hose, they look fine but collapse on the inside. As your cheapest fix, I'd say go for it.
Bob
57chevyragtop
07-22-2005, 03:46 PM
Thanks
Might want to check with the pros at batauto.com, there is no charge to post Q's but if they help, you might consider a donation. these folks have helped me on many occasions and were always correct in diagnosis, post in the domestic forum, give details vehicle type,model year engine size,
read posting instructions!
squashman
07-24-2005, 03:38 PM
Turned out to be a warped rotor. Changed rotors and brakes working perfectly now.
Google
Web AF
