lifted x making noise
View Full Version : lifted x making noise lifted x making noise lance3113f 02-12-2005, 09:24 PM Schludwiller 02-12-2005, 09:32 PM Did you grease the outside of the leaf bushings where it contacts the shackle? Needs a good coat there. Same with the UCA bushings and the mounts. lance3113f 02-12-2005, 09:40 PM nope it didnt. but the wierd thing is it didnt make any noise befor the lift... and as for the front i coated the sleeve... the a-arm does have zerk fittings on it, i just didnt know if i nneded to grease them with the gun right away Schludwiller 02-12-2005, 11:24 PM nope it didnt. but the wierd thing is it didnt make any noise befor the lift... and as for the front i coated the sleeve... the a-arm does have zerk fittings on it, i just didnt know if i nneded to grease them with the gun right away The outside of the urethane bushings need to be lubed when you install them. The zerks are so you can keep them lubed after they're installed. Looking at AC's site they show shackles coming with their lift. If you put in new shackles they need lube between the metal and the bushings. With your suspension just about anyplace I can think of needs lube between a bushing and metal. lance3113f 02-13-2005, 08:17 AM their kit does come with new shackels if your using their single add a leaf, but i did the 3 pack add a leaf so they take the shackels out Schludwiller 02-13-2005, 12:56 PM their kit does come with new shackels if your using their single add a leaf, but i did the 3 pack add a leaf so they take the shackels out Well I guess I would go over the instructions and makes sure I did everything right, check the torque specs, tolerances, and lube everything. Then see if it makes any more noise. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
