Page updated on 06-20-2018
96 Bonneville belt routing
zenith601
02-11-2005, 01:43 PM
I have a 96 Bonneville that lost it's serpentine belt. Does anyone know where I can get a belt routing diagram. (There is not one under the hood)
randman1
02-12-2005, 08:46 AM
Non-supercharged:
http://img.photobucket.com/albums/v155/randman1/Parts/1996L36.jpg
Supercharged:
http://img.photobucket.com/albums/v155/randman1/Parts/1996L67.jpg
This information is right in the owner's manual. If you don't have one they are all over Ebay for about $10 or you can download one from here (https://www.mygmlink.com/pdf/go2content/manual/US/en/pontiac/1996bonneville.pdf).
smonaldo
02-14-2005, 03:30 PM
So, what are you going to do about the motor mount you have to dis-connect to put on the new belt?
Flatrater
02-14-2005, 07:45 PM
The mount doesn't have to be removed. All you need to do is remove the front lower nut, stud and spacer. After that the belt slides in and out.
ecko187
02-22-2005, 02:59 AM
I have a 96 Bonneville and the traction control and abs light keep coming on out of nowhere does anyone know why?
LMP
02-22-2005, 03:12 PM
Most probably flawed bearing on one front wheel, or the sensor associated with this bearing. Common problem.
