1998 Engine capability
Google
Web AF
AJtheMishima
02-11-2005, 12:39 PM
ONLY POST IF YOUR 100% sure
my friends motor went out on the 98 cavi...any motor from like 96 through '00 would fit with no modding....CORRECT???
on ebay there is a (2001 Cavalier Sunfire 2.2 Liter Engine, 52k Miles) would this fit directly in...he's just looking to get the car working again...did a searsh but found a lot of dead end post..(over 15 of them) One guy said he put a 99 in is 96 and it worked....what all would i have to do to get a 01 motor in there....
thanx
eric
Nitrous_Boy
02-11-2005, 03:17 PM
To my knowledge it would fit. Best person to ask would be the dealer, and as far as a motor on EBay i was actually going to buy a 2.2 out of a 01 with that many miles but didn't because he hasn't pulled a motor since 1980.
cousincletus
02-11-2005, 03:26 PM
The junkyard has a book that lists interchangeability for different years.
Classicrocjunkie
02-12-2005, 01:24 AM
No not all motors will fit in. For your 98 you have the 2.2 LN4 OHV which was put into the non- Z24 cavaliers and sunfires GT. These were used from 98-01. 95-97 was the 2.2 LN2 OHV which is basically the same but not quite. If you have a Z24 then you can only put a 2.4L in there with no modification. That engine you see on e-bay, as long as its not the ecotec engine it will swap right it just the opposite as the one you took out. Stick with the LN4 OHV engine because it is a little more reliable than then LN2 for some design flaws. ( i.e. leaky injectors, no belt tensioner, etc. )
AJtheMishima
02-15-2005, 11:53 AM
does anyone know foresure
Google
Web AF
