'95 Camry issues
Google
Web AF
theFREAKnasty82
02-11-2005, 09:39 AM
Hello all,
This is my first time visiting the Toyota forum, so I hope to find some hardcore Toyota experts that can help me figure out a problem on my mom's car; I'm a Chrysler guru, not too knowledgeable about imports. Anyway, My mom has a '95 Camry LE 2.2 and she's had her check engine light on; I was able to retrieve the codes by jumping terminals TE1 and E1 and it spit out a code 71; EGR gast temperature signal is too low. I've physically checked her EGR and it's fine b/c I stalled the engine when I put my vacuum pump to it. Where is the gas temperature sensor or VSV located on this car? I thought I fixed this problem before when the knuckleheads who fixed her car broke off a plastic vacuum piece that sits on top of the water housing by the distributor b/c ironically, that broken piece triggered the light. So if anyone has any suggestions or ideas, I'd gladly appreciate it. Again, thank you in advance.
rbeatar
12-28-2005, 01:31 PM
I have had the exact same set of circumstances with my 95 Camry. I decided to order a VSV and now can't find where it goes on the car. So far it doesn't match the pictures I've seen. I know it has been a while and you appear to have received no response, but how did your problem turn out. Did you find the part location.
Rbeatar
Hello all,
Brian R.
12-28-2005, 04:43 PM
VSV for EGR is on back of engine under EGR valve.
http://i16.photobucket.com/albums/b8/rogersb/VSVEGR.jpg
1 is VSV connector
2 is vacuum hose from EGR valve; connects to port E of VSV
3 is vacuum hose from port "Q" of EGR vacuum modulator to port G of VSV
Google
Web AF
