1992 dodge dakota transmissionsweetdad_40 02-10-2005, 09:35 PM i have a 1992 dodge dakota v8vauto all of a sudden my overdrive quit working 1 2nd and 3rd are fine it just want switch into overdrive please help theFREAKnasty82 02-11-2005, 05:29 AM You could either have a bad overdrive solenoid or a broken band; either way it'll require someone who has access to a pressure gauge to see if your tranny's building enough pressure to engage 4th gear. troy1 02-18-2005, 11:33 PM I would check the solenoids I have seen them come loose its a 25 torx good and snug there is 3 bolts holding the solenoids on. could be a bad solenoid also. was it slipping at all if it just quit one day its got to be the solenoid. kmhebert 03-01-2005, 11:25 PM i had the same problem on my 93 dakota it was the soleniod. so i chenge that and i went ahead and rebuilt the trans. chucko2 01-21-2006, 04:53 PM i had the same problem on my 93 dakota it was the soleniod. so i chenge that and i went ahead and rebuilt the trans. My Bro-in-law has similar problem. Where is this located? And what does it look like. Thanks, Chuck vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
