check engine light / iat sensor
Google
Web AF
jakegday
02-09-2005, 07:00 PM
hi there i just put cold air intake on my car, i was really surprised with how it performs, and the sound, wow, im really excited about it, on to my question..... when i first got done i forgot to hook the iat sensor back up, i noticed this when i was driving and saw my check engine light on, i knew it was the iat sensor immediatly, i pulled over, shut the car off, hooked it back up and started the car, the light was still on, i thought, alright, ill just disconnect the battery when i get home to reset the computer, i did that the light is still on, so then i thought i might need to leave the battery disconected for a little bit longer then 10 seconds, i let it sit for maybe 10-15 mins, hooked it back up, and the check engine light is still on, any input would be greatly appreciated, you guys havent done me wrong with advice yet, so im hoping somebody has an idea, thanks in advace
jakegday
02-10-2005, 04:26 PM
well i was driving to work today and the check engine light shut itself off, so nevermind
noshun
02-10-2005, 05:24 PM
I did the same but you need to leave it disconnected overnight if it happens again. 10 seconds isn't long enough!
jakegday
02-10-2005, 06:37 PM
noshun:
im not tryin to be mean or anything, i totally respect your opinion, ive seen the kind of help you give people, but i did say after that i left it disconnected for 10-15 mins, but if it does happen again, i will let it sit for hours, THANKS
deadBird
02-11-2005, 04:13 AM
Go to AutoZone or any car store, and ask to get the codes read on your computer. The problem might be something completely unrelated, if it comes back that is.
noshun
02-11-2005, 04:41 PM
noshun:
You said 10 seconds first like you would a computer or other elect device and then you said 10-15 mins. Leaving it overnight will always worjk and if it was something else it will comeback on but as it rectified itself it shouldn't although if you do get your codes pulled in the future the IAT will probably show up even though the problem has gone.
Google
Web AF
