windshield washer fluid reservoir
Google
Web AF
Pat Barton
02-09-2005, 02:54 PM
Can someone please tell me how to remove the reservoir from the vehicle? It will leak out all the fluid that is put into it. I can't tell if there is a crack in it or if the hose has come off or has been damaged. I have removed the one screw that holds it solid to the frame. Due to its irregular shape it can't be removed from the top side, at least without removing the brake master cylinder. I was told by a body shop estimator that the inner fender panel would have to be removed as well as the full length fender flare/running board. A little help would be greatly appreciated. Thanks!!
RNRea
05-04-2005, 09:56 PM
What year van?
Pat Barton
05-07-2005, 03:34 PM
It's a '98 Express Van. Hope you can help. Thanks.
RNRea
05-10-2005, 03:29 AM
Hmmm... I have a '92 and the windshield washer resevoir is very easy to remove. It sounds like yours is really difficult to remove. You might ask PICKUP6772, as he writes that he works on these all day. Sorry I can't help you.
Google
Web AF
