90 Lumina 3.1-Help find TCC solenoid plugBluntz| 02-07-2005, 07:08 PM I am having trouble finding this plug, if someone could send a jpg of it on my motor id appreciate it. Haynes manual shows nothing, it has no pitcures or anything. Now if you are facing the motor i see a clip just to the right of the 3 coil packs that has 2 wires coming out but i question wether thats the right one or not. If someone could guide me to it i would appreciate it as i am still stalling at stops and wanna pull this tcc plug to see if it helps. Thanks in advance. jsgold 02-07-2005, 07:18 PM On most 3.1's I've seen it is under the air filter holder assy. May depend on which transmission you have, but of is a 3 speed look there. Remove air filter cover, filter, and then one bolt to remove the holder. Should be a 4 prong plug under there. It is on driver's side for sure, on transmission. Bamaboy1831 02-23-2005, 12:59 PM Explain the stalling issue. Do you smell gas around the engine? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
