crankshaft sensortagle4 02-07-2005, 02:45 AM trying to find location of the crankshaft sensor on a 1993 cavalier it has a 4 cylinder engine. help atlanticl 02-07-2005, 06:20 AM trying to find location of the crankshaft sensor on a 1993 cavalier it has a 4 cylinder engine. help I also wonder where the hell that is. Knifeblade_03 02-07-2005, 09:34 AM K, if crank~not cam~sensor, look right next to your oil filter. Should be a bit above and maybe a touch to R of where the filter mounts to engine. That is for the 2.4L and also the '95 4 bangers [2.3L]. The wiring plug to the sensor should be at 90 degree angle to the sensor , where any oil sensor connector is usually, though not always ,in vertical alignment with that sensor. Knifeblade_03 02-07-2005, 09:46 AM my bad, it's~~~~~~~~` On your 1993 CHEVROLET CAVALIER, the CRANKSHAFT POSITION SENSOR is: UNDER HOOD, PASSENGER SIDE, REAR ENGINE AREA, MOUNTED ON REAR OF INTAKE MANIFOLD Knifeblade_03 02-07-2005, 09:48 AM suggest this site for great free info. www.autozone.com where i found the above correct location for that sensor tagle4 02-07-2005, 02:21 PM my bad, it's~~~~~~~~` On your 1993 CHEVROLET CAVALIER, the CRANKSHAFT POSITION SENSOR is: UNDER HOOD, PASSENGER SIDE, REAR ENGINE AREA, MOUNTED ON REAR OF INTAKE MANIFOLD thanks alot mhowe1182 03-05-2006, 03:06 PM ive got a 90 cavvy and my crankshaft senosr is down on driverside backside of engine about the same level as brakes. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
