1994 Golf question
Google
Web AF
reli
02-06-2005, 04:23 PM
This just started last night and whenever I come to a stop, the engine oil pressure light starts flashing, but when I take off, the light stops flashing. I'm just wondering what could be the problem, if it's something I can fix easily or should I take this to a mechanic?
boschmann
02-07-2005, 03:56 PM
Get the oil pressure checked with a mechanical gauge. If it's okay (min 29 psi w/engine hot) then it's probably one of the sensors. If it's low it may need an oil pump, how many miles are on it?
reli
02-07-2005, 10:44 PM
i have about 134k miles on it and the oil is full i just gave the car an oil change.
boschmann
02-08-2005, 01:52 PM
You would have to put a mechanical oil pressure gauge into the oil sensor hole on the back end of the cylinder head, this has nothing to do with a being full. What brand & weight oil did you use? Which brand oil filter also?
reli
02-09-2005, 06:01 PM
I'm using both Penzoil for the oil 10w-30 and the penzoil oil filter.
mckenna
02-09-2005, 07:25 PM
I have a 94 golf gl (gas). The oil light was flashing all the time, and beeping too. The local vw shop said to do an oil change and put in 15w40.
boschmann
02-10-2005, 04:32 PM
10W-30 is the rccomended, 15W-40 or 20W-50 may help, but I would have the oil pressure checked.
Google
Web AF
