89 Deville......Engine Coolant Fan..Help
piesmi
02-06-2005, 08:37 AM
The Engine Coolant Fans will not stop running ( which is draining the battery) I have had to disconnect the battery each time I park it for the night. I pulled the fuse and the relay and it still kept going!
Any suggestions?
Thanks.
MarkC
02-06-2005, 12:42 PM
There are three coolant fan relays located in front of the drivers side shock tower under the hood. Remove them one by one until the fan stops working. The relay you remove that stops the fan, is bad. Replace that one and you should be all set.
piesmi
02-06-2005, 07:42 PM
Thanks a million, Mark C. That did the trick!
