Interior light by the a/c heat vent switches blewblazzingbrandon 02-06-2005, 03:15 AM I have a 97' and light backlight behined the ac/vent/heat switches is no longer coming on. So at night, I have this big black spot and can't see the controls. Any ideas, blown fuse? disconnected wire? ACOVA 02-08-2006, 02:51 PM I Have The Same Problem, Is There A Fix For This? 4Wheel 02-08-2006, 05:40 PM If the rest of your dash lighting is copasetic then the bulb fell out or is burned out. Simple problem but have fun trying to get to it!!! corbinwaterski 02-12-2006, 10:12 AM I don't have the specifics for your '97, however on the earlier models, through -'95, the bulb burns out behind the climate controls. In the earlier models you just pop off the face behind the knobs and there is a clear plastic piece. Behind this clear plastic piece is the bulb. The older models have a green cover that goes over the bulb that needs to be saved to put on the new bulb. Again, I don't know specifics of the '97's, but I hope this helps some. Good luck, keep everyone posted. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
