1999 Pontiac Grand AM SE radio uninstallation help
angrysk8r
02-05-2005, 11:39 PM
How do you uninstall the factory radio on a 1999 Pontiac Grand AM SE?
All help would be appreciated
mcbeefer
02-06-2005, 02:21 AM
how do u mean as far as taking it out you
-turn your key on and pull the parking brake
-shift to neutral or farther as needed to pull the bezel off
-u should be able to turn off the key now and remove it leaving the shifter in neutral
-now pry carefully pry off the bezel (it is just held on by clips)
-u'll now have to unhook the traction and the hazard switch harnesses
- now you have access to the radio and is fairly easy take out the 4 screws and un hook the radio
mcbeefer
02-06-2005, 02:24 AM
that is if the theft lock is not inabled not sure how to disable that sure some one here knows
sorry
sorry
angrysk8r
02-06-2005, 10:27 AM
thanks for everything, now i can finally install the new cd player
