Cavalier Guagesjwisbell 02-05-2005, 05:53 PM Guages in 2002 cavalier quit. Speedometer, odometer, tach, fuel, temp. All the gauges in center of dash. The outside ones still work. What would cause this?? hopeless4life 02-05-2005, 09:42 PM check ur fuses first Classicrocjunkie 02-05-2005, 11:09 PM ^^^... more than likely the problem jwisbell 02-06-2005, 09:06 AM Checked all fuses inside and out. They are fine. Also noticed the daytime running lights are out. Could this be the bcm. EnjukuRacing240sx 02-06-2005, 03:24 PM if your daytime running lights are out, then thats gotta be one of two things.... your drl relay is out or you need to replace the little microprocesser unit which is actually in the instrument cluster vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
