93 Cav Tach help
Google
Web AF
chevyguy93
02-04-2005, 09:26 PM
I've been reading posts about putting a tach into automatics. I've bought a tach for about $40 canadian, and it looks pretty good. It's only got settings for 4-6-8 cyls. Now, i here that i can just hook it into the wire that comes off the coil packs, or what ever it's called, hehe. But there's 2 of them, and so i'll only be getting half a normal reading. I don't got money to go out and buy a "converter" to amplify it. Is there anything else that i can do? I'm great with electronics, and do repairs. does anyone have a schematic or know what's inside one of those converters? Or if theres any other places i could tap into to get a full rpm reading. From what i understand, there should be a tach wire somewhere for mechanics. hmm. Anyways, thanks for the help. i'll check back soon to read replys =P
hopeless4life
02-04-2005, 10:16 PM
If ur car is fuel injected the tach signal will be stronger at an injector, There will be one wire that will be common to all the injectors, thats the wrong one. use any one of the uncommon wires. In your car their should be more wires than that at the coil pack though, In Gms the white wire at the coil pack is generally the tach wire, or it could be a purple white. either way i hope this helped
chevyguy93
02-04-2005, 10:19 PM
Oh. i forgot to say. it's a 4 cyl. distributorless. not fuel injected.
EnjukuRacing240sx
02-06-2005, 03:33 PM
it is a purple and white wire. splice off that youll be golden
chevyguy93
02-06-2005, 04:39 PM
and where would i locate this purple and white wire? I've searched before, but had no success.
hopeless4life
02-06-2005, 10:42 PM
Follow your spark plug wires from the spark plug back. At the end of the spark plug wires there should be a coil pack or a distributer. At that there should be a plug, with wires coming off of it. Tap on to either the white or the purple white for your tach signal.
chevyguy93
02-07-2005, 12:20 AM
but isnt there 2 coil packs? which then when hooked to my tach, my signal will only be half of what it should be. so the tach will be wrong.
aint i right?
noshun
02-07-2005, 01:01 AM
aint i right?
It shouldn't but if it does then splice into both!!!!!!!!!!!! :lol:
chevyguy93
02-07-2005, 08:33 AM
haha, yea. splice into both :lol: . i thought there were 2, 1 per 2 cylinders or something like that. i'll look next time i get a chance too.
hopeless4life
02-07-2005, 09:30 PM
Its like talkin to an FN brick wall sometimes
hopeless4life
02-07-2005, 09:31 PM
tap it on to the damn purple white or white already, if it don't work then ask again.
noshun
02-07-2005, 09:56 PM
Alright Guv'na calm it!
chevyguy93
02-07-2005, 10:30 PM
hmm. well. i tried, it dont work! lol. shows half the rpms.
noshun
02-08-2005, 01:05 AM
bet you didn't try both!
EnjukuRacing240sx
02-08-2005, 02:18 PM
im bettin the same thing
Google
Web AF
