break ?
Google
Web AF
Leoaviles
02-04-2005, 07:09 PM
whats up guys, so i got a 98 blazer and right rear break was actin up, it seemed as if the break was stuck on the rotor. I took it to get fixed and the guy just changed the rotor the pads and i paid him 90 bucks for everything including parts. So i thought he fixed it but i start smelling the funky smell of metal or something and it seems as if the noise was gone but the break is still stuck
i take it back and the dude said that it was problably the break hose.
im standing there thinking werent you supposed to fix that problem. So he tells me he is going to try the hose first since sometime they dont allow the pressure to release from breaks. and if that doesnt work than he would replace the calipers. i couldnt find the hose at autozone, oreilies, or the dealer so i have to wait for the shippment for 3 days.
this really sucks especially the smell
anyone have a problem like this or similar?
BlazerLT
02-04-2005, 07:32 PM
Take it back to him and demand him to complete the job.
Leoaviles
02-04-2005, 07:48 PM
i will do that 1st thing tommorow morning. i hate the fact that he made me waste my time when the problem continues.
Rick Norwood
02-05-2005, 12:20 PM
This sounds like a stuck caliper to me, or the slides (bushings) that the bolts pass through are stuck, causing a misalignment.
I afraid I don't understand the hose part. If the caliper was properly bled, the hose should be fine unless it is damaged or pinched.
If you remove the tire and have someone lightly apply the Brake pedal, you should see the caliper tighten and then release when the pedal is released. If not, your caliper might be stuck. (You might have to put a couple of the lug nuts back on to hold the rotor.)
Did you take this to a reputable garage?
mike2004tct
02-05-2005, 02:15 PM
I got a bridge for sale in Brooklyn,NY; I'll throw in a brake hose only if you purchase within then next 30 minutes.
The guy is handing you a line.
Either your caliper is corroded (rear brakes don't function too often)
or your parking brake cable/caliper spring is malfuntioning. Exercise your parking brake numerous times while the truck is stationary, you may free it up. As Rick noted, have someone help you so you can watch the caliper for movement.
Leoaviles
02-05-2005, 06:31 PM
my foot break is not working at all, but we got the hose changed today and the funny smell topped. the rim doesnt seem to get hot either. hopefully thats what it was. Im just glad it is over cause i hate havein problems with my transportation. thanks to all that helped
toenailclippers
02-05-2005, 10:36 PM
I had the same problem. whe he changed your stuff out, thhe didnt change the hose. the hose was collapsed nd therefore kept the caliper locked up. the same thing hapened to me, only my brakes caught on fire!
rlith
02-06-2005, 08:10 AM
So your e-brake isn't working? Why didn't he replace/adjust the e-brake pads? Or did he disconnect it?
TonyMazz
02-07-2005, 09:49 AM
Take it back to the same guy or get someone who knows what the hell their doing.
The caliper is stuck, take the caliper off and disassemble...and clean the sludge out of the piston. clean the caliper in a parts cleaner, and install a new caliper kit.
Also new pads should have been burnished in where the light apply the brake and score the pads.
A complete brake job is more than just replacing pads and turning a rotor...it's cleaning up the caliper..i.e. wire brush, cleaner, new o-ring, and cleaning out the cylinder.
Rick Norwood
02-07-2005, 09:56 AM
Exactly, just because the smell went away doesn't mean the problem is solved. Your caliper is most likely stuck.
Take it somewhere that knows what their doing or you'll hate walking even more when your brakes fail and your ride is gone. Don't screw around with brake problems!
Leoaviles
02-07-2005, 11:53 PM
i was wrong the hose helped out a little but the caliper is still stuck because. i feel that my car isnt running like it used to it feels stuck and is not running smoothly. Im kind of short on money thats why i havent tooken it to have the caliper changed. Should i replace both rear calipers? Is this job pretty easy or does it take alot of time? Maby i can do it my self and save some money.
How much does a new caliper cost?
is there anything that goes along with the caliper that i should replace?
thanks
rlith
02-08-2005, 06:36 AM
You don't need the caliper, you just need the slide pins... an 18mm box wrench and a hammer will do you fine. Spread some antisieze on the slide pins before putting them on. Slide pins are about 3 bux a piece.
Leoaviles
02-11-2005, 12:29 PM
so i finally fixed the break problem and felt the weight lift off my back. It ended up being the stuck caliper. i replaced it and now my blaze runs smooth. thanks for all the help guys
Rick Norwood
02-11-2005, 01:26 PM
Good news! Congrats! Thanks for posting the results.
BlazerLT
02-11-2005, 03:32 PM
Why didn't you get the mechanic to fix it?
It was his responsibility.
travis2822
02-11-2005, 05:47 PM
i had the same problem with my 99 blazer. i changed the master cylinder and the problem was fixed. it was the last thing i thought of. good luck
Leoaviles
02-11-2005, 07:36 PM
i didnt want to bother with him so i got with a friend and fixed it
autozone was charging me about 65 for 1 caliper though so i went to orilyes sp and luckily i found it there for 35.
but i gues we all learn from our mistakes, next time i will find a better mechanic or better yet do it myself
Google
Web AF
