Common Blazer problems
Google
Web AF
Lafarga
02-03-2005, 10:02 PM
Hey. Looking at a 99 Blazer. 2wd. Wondering what the more common problems for a Blazer are. Anything serious? Thanks.
Cadillakin'98
02-03-2005, 10:11 PM
Your driving habits and how well you maintain a vehicle determines majority of the problems you are likely to encounter
rlith
02-03-2005, 10:36 PM
Things to watch for
Ball joints
Idler Arm
Stuck injector
hub bearings
Dex-crap (dexcool) sludgeing
Door pin bushing sag
bowtie_pasta
02-04-2005, 12:43 AM
Are the door pin bushings something a home mechanic can fix?
My driver side door seems to be sagging and not closing like it used to.
BlazerLT
02-04-2005, 03:46 AM
Yip, can easily be swapped out.
rlith
02-04-2005, 05:59 AM
You can get the new pins and bushings at any autoparts store...
bowtie_pasta
02-04-2005, 06:53 PM
Thanks guys! :)
bowtie_pasta
02-04-2005, 06:54 PM
Can I ask another question? How would you tell if yours are worn and in need of replacement?
swalt
02-04-2005, 10:15 PM
Grab the door from the top right corner and see if you can push up on it. If there is movement, you need to replace a pin. Do both pins and bushings in the door at the same time. Both pins need to be popped out and the door taken off the hinges anyways in order to get the bushings out.
Google
Web AF
