Key stuck in ignition - '95 Metrodroidbot7000 02-03-2005, 03:45 AM OK- It will turn the engine and idiot lights off but won't rotate to Lock Position where you can take out the key, and the battery keeps draining overnight. Can any one suggest a manual with clear pictures/instructions or, better yet, personal experience with a solution? Thanks in advance... Inni 02-04-2005, 12:21 PM Well i dont know if this will work but try and shake the steering wheel left to right while trying to take the key out. If that doesn't work, push the key in more and try turning it to the lock position. It should work. I worked for me but i cant garuntee anything. Just some suggestions. Good Luck. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
