throttle body port and polish
Google
Web AF
GotZ24
02-02-2005, 07:45 PM
i was wanting to port and polish my throttle body, actually i was gonna pick up one from a junkyard and do it to that one, and was wondering what to do about the butterfly valve. i was thinkin 59mm port. are there any 59mm butterfly valves i could replace mine with, or would i have to make my own 59mm plate?
also, anyone know where i could find a bumper extension/ground effects for my 02 Z24? GM wants $200 for one!
Knifeblade_03
02-04-2005, 12:43 AM
No clue on the TB work, but check out J.C. Whitney for ground-effects packages.
noshun
02-05-2005, 01:12 PM
You could make your own but it would have to be the smae thickness. Try looking at tbs from larger motors. You can stick one and and just polish the inside but nt remove too much material. You can port a TB. This is where you enlarge the ports on the head or manifolds. Your best bet is to take some Vernier Calipers to the wreckers and just look around. You may ewant a few butterfly's in case the one you get doesn't match up.
Google
Web AF
