Headlight issue
Google
Web AF
SlyBry
02-02-2005, 06:37 PM
1997 Cavalier 2.2L with 78,000 miles.
I noticed the other day that my driver's side headlight was out, so I went down to Autozone and got a pair of relacement bulbs. After changing both headlights, the driver's side was still out. So just to be sure that I didn't buy a bad bulb, I tried it with the working bulb I installed on the passenger's side, and got the same result.
Then I figured that it must be a fuse. I'm not that lucky. The fuse didn't look blown, but I replaced it anyway and got the same results. So then I grabbed my multimeter. I tested 12 volts at the fuse, and 11 volts at the socket. WTF? Why isn't this working?
Any ideas?
Classicrocjunkie
02-02-2005, 11:49 PM
did you touch the bulb at all?
SlyBry
02-03-2005, 06:33 AM
did you touch the bulb at all?Nah, it was cold out, so I was wearing gloves. Besides, I have 4 confirmed "working" bulbs that all work fine on the passenger's side, but don't do jack on the driver's side.
Knifeblade_03
02-04-2005, 12:36 AM
And the socket that plugs into the bulb shows current, right? If so, does any of your park/sidemarker/tail/third brake bulbs fail to work? It is a weirds thing, but a failed bulb anywhere above can cause an intermittent fail at the socket when it is plugged in,
cousincletus
02-04-2005, 04:14 PM
Check the ground.
noshun
02-05-2005, 01:18 PM
is the socket clean?
Google
Web AF
