interior lights on 94 camry won't turn onsonu94 02-02-2005, 02:44 PM I have a 94 camry LE 2.2Li with sunroof and the interior dome light and map light by the sunroof control wont turn on. Does someone know if there is a possible problem with a fuse or if someon has had similar problems. thanks, sonu sonu94 02-02-2005, 02:44 PM thanks for the tips Daniel M. Dreifus 02-03-2005, 08:48 AM I'd check the switches and ground connections. I also have the 1994, 2.2 but without sunroof or map light. Sometimes the dome light does not come on when opening a door (most recently left rear door). Taking out the switch and spraying with WD-40, then cleaning the mounting bolt (which also supplies the ground connection) solves the problem. Could be something similar with your switches. GSS123 02-03-2005, 10:55 AM Is the bulb still good? ice745 02-05-2005, 10:18 PM I have a 94 2.2 camry without the sunroof also. My lights wouldn't work and also did what Daniel did. This worked for me. If you turn them to On, and not Door, and they still don't work you might have a burnt bulb or a loose one. I sometimes hit my dome light and the vibration resettles the bulb and it works. I wouldn't recommend doing this, lol, but just showing that loose bulbs may be a problem. I would take out the bulb. Check the bulb itself for continuity to make sure it hasn't blown. Then with a test-light or a multimeter test the terminals while the switch is on to narrow the problem down to wiring or fuses. If you get 12 volts DC to the terminals then you may want to try a different bulb, or maybe cleaning them to get a better connection. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
