ZR3? VS. s10 blazer
metallica21156
02-02-2005, 08:04 AM
whats the diff between the s10 blazer and ZR3? blazer?
rlith
02-02-2005, 08:46 AM
You can see the side by side comparison at www.zr2.com on the front page...
RPO ZR2 only full ladder-type frame with modified suspension mounting points which provide:
100mm wider track (3.9 inches wider than regular S-10)
Three-inch suspension height increase
Enhanced front (7.25" ring gear) and rear (8.5" ring gear) axles w/ 3.73:1 rear-axle ratio
Larger wheel and axle bearings
31 x 10.5R-15 LT/C black wall off-road tires (BFG A/Ts on pickups and BFG Long Trails on BlaZeR2)
46mm gas pressurized Bilstein Monotube shocks
Rear axle track bar (pickups) / rear sway bar (BlaZeR2)
Wheel flares (black on S-10 pickups and BlaZeR2 / body-color on Sonoma pickups)
33mm (early model) / 28mm (late model) front anti-sway bar
Skid plates
metallica21156
02-02-2005, 03:08 PM
can i convert my 95 to having the same thing? wider stance is what i'm looking at.
rlith
02-02-2005, 06:47 PM
Sure, you can convert your jimmy to that, just change the frame, rear, springs, shocks, axels, axel bearings, and front diff.
metallica21156
02-03-2005, 03:05 PM
i'm trying to get really go shocks. i was told that by going to a stiff shock that i could raise the truck by a inch. by just bolting on the new shock from stock. is this true? i also was looking at getting the Rancho RSX shock. ever used it? recomend it or one that will lift the truck?
rlith
02-03-2005, 06:03 PM
Shocks will not lift you. You might get around an inch cranking the torsion bars, but you will tear through ball joints. I have a rancho rsx for my steering stabilizer. If you're looking for lift, check the trailmaster 5" suspension lift (It's the best as it keeps geometry stock)
