rear door speakersTheFugitiveMind 02-02-2005, 02:00 AM i have a 01 passport how do i go about taking apart the interior door to access the speakers? it has power windows. Thanks! 2eyefishclaw 02-03-2005, 01:42 AM remove the inside door handle the handle you pull on to close the door is not solid the front of it is a cover behind it are two screws afte rthose have been removed you should be ablee to pull the door panel off start at one of the bottom corners its going to be a bit tough to take it off jus pull ahrd it will pop out vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
