problem with 1st and 2nd speed at first changes
Google
Web AF
manolispapadakis
02-01-2005, 06:13 PM
every morning i have problems with the 1st and 2nd speed at the first changes. i need much more power to push the lever if i want to change speed. After 15 minutes everything is working fine. The problem began when a technician spilled valvoline by accident inside the gear disk !!!
boschmann
02-02-2005, 08:37 PM
Oil was spilled onto the clutch? Does it grind into reverse? If so, I'd worry the clutch disc is ruined. Otherwise perhaps a gear oil change, Redline oil seems to help with this type of problem.
manolispapadakis
02-10-2005, 11:41 AM
No it doesn't grind... There is no strange noise when i'm driving...I don't know the redline oil...will it reduse the attrition inside the gearbox...how can i find it in the local market???
Scanner
02-10-2005, 12:32 PM
Make them fix it!
boschmann
02-10-2005, 04:29 PM
As long as the clutch disk hasn't deteriorated the Redline oil may work. It helps with stiff shifting gearboxes due to wear & age. Not all stores carry it, but you can find it with a Google search. If the clutch disc were going bad from the oil I would expect it to be difficult to get into reverse also.
Google
Web AF
