98 camero won't go out of park
Google
Web AF
bigs
02-01-2005, 11:30 AM
My daughter can't get her 98 camero out of park, any idea's, before she calls a tow truck?
Bridget
02-03-2005, 08:36 PM
I have a 95 Camaro and I had a shifting from park problem. When I would press in the button on the gear shift and press the brake, it was hard to shift from park. Sometimes it would sound like plastic breaking and it was hard enough that coins came flying out of my ashtray.
I removed the trim around the shift (it just pops up) and looked at it in park then tried shifting. There is a plastic tab that has a bend on it that should release once the button has been pressed. Mine wasn't releasing. I used WD40 on the tab and the area it connects into. I haven't had it to stick since. I hope this helps.
bigs
02-04-2005, 03:19 PM
Bridget, thank you so much, works like a charm now. And such a
cheap fix. She thanks you, and I thank you.
Bridget
02-05-2005, 01:19 AM
Glad I could help and even happier it was something that simple. I am so thankful for this forum (stumbled on it) because it really helps people. Have a great day and you are welcome.
Google
Web AF
