new camarotxchevy 02-01-2005, 08:56 AM just bought 88 2.8 liter 5 speed and the fuel lines and tank has sand and gunk in them i need to know how hard it would be to change the tank and lines. i will eventually put a 350 in it but i cant right now cause i dont have a 5 or 6 speed trannie to match up with my 350. it has about 380 hp acorrding to desktop dyno. how much power will the factory 5 speed in the v6 handle if adapted for awhile until i find a stronger one Autofreefindersguy 02-01-2005, 09:41 AM I doubt the V6 tranny would hold up at all to the torque of a 350... As far as the tank goes, I have never did that job but its a good idea to replace the fuel pump while your doing that change... Good luck/skill! Savage Messiah 02-01-2005, 11:30 AM different bolt patterns on the bellhousing, they won't go together Chevyracincamaro 02-01-2005, 11:32 AM the sixer trannies definitely will not hold up. the eights in the third gens only came with autos. if you want a stick you can either find someone to build the T5 you have or go get a T56 swap in... 454cam 02-01-2005, 11:50 AM Dropping the fuel tank and changing out the lines is not very hard at all. A little knowledge and a Chiltons should help. good luck txchevy! KPot2004 02-01-2005, 01:19 PM the v8's in the 3rd gens also came with manual trannys vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
