82 honda civic cvcc 1.5l m/t wont iddle.
manny1
01-31-2005, 06:15 PM
what are all the vacume solinoids on the fire wall and would they cause the engine to blow oil through the carb if they dont work,car barly runs when you give it gas it feels like its funing on 2 cylinders.what could it be any help.
aquarius
01-31-2005, 06:39 PM
hmm i don't know have you checked the hanes manuel for help
it could be a vacuum line i guess causing something to not work in sync
aquarius
02-01-2005, 05:37 PM
well actually see there shouldn't be any oil near the intake or carb so you might want to check everything else also
cvcc_wagon
02-01-2005, 06:16 PM
way out of your league boys, what he is talking about is this (http://www.redpepperracing.com/gallery/albums/album650/aaa.sized.jpg), a second gen cvcc... nightmare. but oil shouldn't be able to make it's way in anywhere, where do you see oil?
it sounds as though you have a clogged fuel filter(s) or perhaps the carb just needs a rebuild (armature beware, very complicated) what do you mean it runs like it's on 2 cylinders? does it run like that all the time or after you've been driving for a while?
i would check your filters, there is one canister style one on the tank and another inline one in the engine compartment. if that doesn't help things send me a PM, i have a carb with vacuum boxes still attached you can have inexpensively if you like, it ran fine till the day i pulled it out.
manny1
02-01-2005, 06:31 PM
no i changed the fuel filters in front and the rear,and oil is coming out of a vacume line that seems to be coming out from the bottom of the carb to the air cleaner,my next thing is to check compresion i was told.thanx for your info.
Figori
02-01-2005, 06:56 PM
My bro didn't see the year... I apologize...
cvcc_wagon
02-01-2005, 11:35 PM
that's not a vacuum line, it's the pcv valve hose. it goes to the neck on the valve cover to release pressure from the crank case. there shouldn't be any great amount if oil that can make it up that line. if there is there may be some other issues like compression as you mentioned, low compression could mean blow by on the rings which would mean greater pressure in the crank case. do a compression test. are you burning a lot of blue smoke?
