What are the symptoms of a bad diff?
Budanam
01-30-2005, 06:14 PM
I have been having trouble with my 88 4runner. It has a 3vz-e engine efi 3.0 v6 with an auto transmission. I just changed out the fuel filter and made sure that my vaccum hoses where in good shape so I don't think the fuel system is to blame. The engine gets plenty of power and fuel but the truck jerks back and fourth when I am accelarating especially up hills on the highway. It is intermittent. I know that my rear diff is on its way out but I am not sure if that is the problem. I guess it could also be my auto trans. What are the symptoms of a bad trans or rear diff? My trans seems to shift okay. maybe a little rough but not too bad. There is plenty of fluid. Sometime my overdrive doesn't kick in when I push the button but for the most part it does work. The rear diff makes a small klunking noise when I decellerate and that has been on going for a while. Any ideas on what the problem might be? Please help me save my beast.... Thanks
Brian R.
01-30-2005, 10:01 PM
If you haven't recently, grease the fittings in the rear propellor shaft.
Mrbikerman
01-31-2005, 06:12 AM
It might be a cylinder misfire, I had a problem very similar to yours, and thought it was my auto tranny, but it turned out something had "eaten" through my spark plug wire.
Budanam
01-31-2005, 02:47 PM
HI Brian R. Thanks for the help. I will try and have the shaft lubed. I noticed that the problem only occurs when I am accelarating. It doesn't happen when I push the gas with the engine in park. It also doesn't happen when I am rolling along with my foot off the gas. That is why I am thinking it may be an auto trans problem. Does this info give you anymore ideas?
