wiring diagram for a 02 cavalier...im gonna bypass that class 2 data thingyboltz2012 01-30-2005, 02:10 PM i got a harness for a saturn that the wires can be moved around on and i need to find the wiring diagram for an 02 cavalier so i can rearange the wires on my harness accordingly...i dont care about the door chimes working or not..so no need to relocate the factory radio..thanx in advance... noshun 01-30-2005, 02:55 PM i got a harness for a saturn that the wires can be moved around on and i need to find the wiring diagram for an 02 cavalier so i can rearange the wires on my harness accordingly...i dont care about the door chimes working or not..so no need to relocate the factory radio..thanx in advance... Back of a Haynes Manual boltz2012 01-30-2005, 09:45 PM Back of a Haynes Manual thanx for the info..i was hoping someone knew of a site i could go to that might have one cuz after buying all this stereo crap i am short on cash...may have to wait to put it all in until i get that manual...and can you tell me about body kits for this model cavvy..cuz all i can find is 2 of them and they look like they belong on a rice burner...thanx Classicrocjunkie 01-30-2005, 10:42 PM there like 14 bucks... ^^ hopeless4life 01-30-2005, 11:09 PM If your gettin rid of your factory radio don't hook up the aftermarket radio accesory wire to theswitched accesory unless it tests to have power and not pulsed power. The newer Gm radios use a pulsed radio turn on lead and after market use constant acc turn on. If it has this just run a wire to the brown wire in the ignition harness or jump it off a switched acc fuse. Also if you got a harness for it already it should just be plug and play, except for the acc wire. noshun 01-30-2005, 11:32 PM If your gettin rid of your factory radio don't hook up the aftermarket radio accesory wire to theswitched accesory unless it tests to have power and not pulsed power. The newer Gm radios use a pulsed radio turn on lead and after market use constant acc turn on. If it has this just run a wire to the brown wire in the ignition harness or jump it off a switched acc fuse. Also if you got a harness for it already it should just be plug and play, except for the acc wire. He's not talking about replacing the stereo! boltz2012 01-31-2005, 01:43 AM He's not talking about replacing the stereo! thanx for the help guys...i got it all going now...i found a site earlier that had it all down pat... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
