97 cavalier passenger side window off track
Google
Web AF
joey_t
01-29-2005, 07:38 PM
I'm trying to repair my passenger side window on my 97 chevy cavalier...I've managed to get the door panel off but I still don't see how I'm going to get the window out (if I even need too)
the two plastic clips or whatever that hold the window in place, on the rear one, the screw that holds the window in the clip broke and now the window has come out, where can I get another screw to hold it in place and how am I going to be able to reach it?
do I need to remove more off of the door or somehow slide the window out?
thanks.
Boomsly
01-30-2005, 11:28 AM
I'm not sure if you need to remove the window but I'd see if you could get a new clip to put on asap from auto store/shop quick just so the other one doesn't break and drop the window, that wouldn't be good. Maybe try a junkyard if your having trouble getting one I had to get a new PW motor and it came with those clips so yuor probably better off going to a junkyard.
joey_t
02-02-2005, 12:26 PM
well I did manage to fix it...was easier than I thought
the clip was still attatched to the window arm or whatever its called, the screw/bolt that holds the window in place was just missing, but I managed to find something in similar size to hold it in there.
thanks.
Google
Web AF
