Blazer - Random Blinker Clicking Noiseklei0258 01-29-2005, 04:19 PM I have a 99 Blazer which has developed a problem where the blinker makes it's clicking noise randomly while I am driving (about 40% of the time), even though I don't have the blinker on. There doesn't seem to be a pattern as to when the clicking noise occurs - they only thing I have been able to figure out is that when I press in the brake pedal, the clicking stops. All the blinker/turn signals work fine when I turn them on, but I can't figure out why it continues to make the noise. I tried to replace the "flasher" under the dashboard but that didn't make any difference. I would really appreciate any advice you could offer me. ricksza 01-29-2005, 04:26 PM Are you sure the noise is coming from the flasher? The only time it should click is when a draw is pulled through it by the turn signal or hazard switches. doozie 01-29-2005, 09:23 PM There are several other threads about this problem (I had it too). Do a search on the forum. dandersen 02-14-2008, 12:35 PM so now i have the same issue how did every one fix that vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
