inst , dome light solution 89 S10 blazersnojunki 01-28-2005, 11:32 PM my dash went dark after using the cig lighter I tore every piece of tape and loom from blaze looking for a short. many people have the same problem i'm finding out. I fixed all my problems by grounding the ecm neg wire. every thing works fine now. ps everything but my 4WD doesn't engage or light up front axle : need help there still. s10bajadan 01-29-2005, 12:55 PM Is this a manual 4x4 shifter? If so it could be the vaccume hub switch is bad. check out www.s104x4.com click on tech articles then vaccume diagrams.I would start with checking for vaccume leaks,if check ok replace vaccume hub switch. snojunki 02-01-2005, 05:44 PM Is this a manual 4x4 shifter? If so it could be the vaccume hub switch is bad. check out www.s104x4.com click on tech articles then vaccume diagrams.I would start with checking for vaccume leaks,if check ok replace vaccume hub switch. :grinno: yes shifter on the floor. i,ve checked all vaccuum and replaced the vaccuum switch. still no 4X4. it worked the day i bought it and never since vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
